ONTAP Hardware
Upgrading IOM6 Firmware Before Moving Shelf
MFuron
I am trying to upgrade the firmware on some existing IOM6 modules in advance of re-purposing shelves on a FAS8200.
I have a current FAS8040 with DS2246 shelves with IOM6s.  The FAS8040 is running 9.1P13.  I installed the shelf and ACP firmware files.  When I upgrade the firmware, the shelf firmware upgrades fine (the output of "sysconfig -a" shows the firmware at 0191).  However, the ACP firmware status shows something I have not seen before:
::> storage shelf acp module show -instance
Node:node-01
Module Name: 1.0.B
Adapter Name: 0a
MAC Address: 00:a0:xx:xx:xx:xx
IOM Type: iom6
Shelf Serial Number: 6000xxxxxx
Protocol Version: 0.0.00.00
Firmware Version: 00.00
State: unsupported
Last Contact: 502
Node: node-01
Module Name: 1.0.A
Adapter Name: 0a
IOM Type: iom6
State: firmware-update-required
Last Contact: 502
2 entries were displayed.
I cannot find any documentation about what those state messages mean.  The ACP firmware version shows 00.00.  Has anyone tried to do this before?  I want to get the firmware to a level where in-band ACP is supported so I can connect the shelves to the FAS8200.
6 REPLIES 6
aborzenkov
Is ACP active? Paste output of "storage shelf acp show -instance"
MFuron
Certainly.  Here is what I have:
node::> storage shelf acp show
Node                Channel          Connectivity
node-01    in-band          active
node::> storage shelf acp module show -instance
               Node: node-01
        Module Name: 1.0.B
       Adapter Name: 0a
        MAC Address: 00:a0:98:xx:xx:xx
           IOM Type: iom6
Shelf Serial Number: 6000nnnnnn
              State: unsupported
       Last Contact: 502
               Node: node-01
        Module Name: 1.0.A
       Adapter Name: 0a
           IOM Type: iom6
       Last Contact: 502
aborzenkov
You have IB ACP and firmware version that does not support it. You need to switch to OOB ACP, update firmware and then switch back to IB if desired.
Linuxtom
Hello,
I have the same issue
When i go bak to OOB, acp iom6 stay in an unknown state and I can't do the firmware upgrade
In In-Band config :
Node: cluster1-01
Module Name: 1.0.A
Adapter Name: 0a
MAC Address: 00:a0:98:xxxxxx
IOM Type: iom6e
Shelf Serial Number: 6500xxxxxx
Protocol Version: 2.1.01.22
Firmware Version: 01.22
State: active
Last Contact: 21
Node: cluster1-01
Module Name: 1.10.B
Adapter Name: 0b
IOM Type: iom6
Last Contact: 24
In Out-Of-Band config :
Node: cluster1-02
Module Name: 1.0.A
Adapter Name: 0b
IOM Type: iom6e
IP Address: 192.168.1.6
Assigner ID: 1892869837
State: active
Last Contact: 429
Node: cluster1-02
Module Name: 1.10.B
Adapter Name: 0a
IOM Type: iom6
IP Address: 0.0.0.0
Assigner ID: 0
State: unknown
Last Contact: 489
No problem with ACP IOM6e state : unkown->initializing->active
ACP IOM6 state stay unknown 😞
Is there a command to force the initialization of iom6 to do the upgrade ?
Thomas 😉
Linuxtom
I attach the ds2246 to another 2240-2 with ontap 9.0P4. When I use IB mode, It tell me the same thing : need firmware upgrade.
But in OOB mode, I see something else :
Node: cluster2-02
Module Name: 1.10.A
Adapter Name: 0b
IOM Type: iom6
Shelf Serial Number: 6500xxxx2
IP Address: 0.0.0.0
Protocol Version: 0.0.0.0
Firmware Version: 0.0
Assigner ID: 0
State: awaiting-bootp
Last Contact: 2289
The state is "awaiting-bootp" ... What does it mean ? I found nothing about that. Someone have an idea ?
Thomas
aborzenkov
Usual recommendations when some IOM fails to join OOB ACP
  • try to replug LAN cables (plug out, wait couple of minutes, plug back in)
  • try to disable and then enable ACP again
  • try to reseat IOM in question
All failed, case with NetApp support is in order.
