ONTAP Hardware
cabling FAS2240 with shelf DS2246
ol15
hello,
can you tell me what is the good cabling configuration: or are they all good cabling schema?
version1:
or version 2:
regards
1 ACCEPTED SOLUTION
hariprak
Hi,
Refer https://library.netapp.com/ecm/ecm_get_file/ECMP1149275 and  Check page 3 of this quick Installation and Setup FAS2240 instructions, which clearly shows the cabling for what you are doing.
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
1 REPLY 1
hariprak
Hi,
Thanks
