ONTAP Hardware
e3a: state lag_inactive,
mouhyi75
I have this problem :
vifmulti-cifs: 0 links, transmit 'IP Load balancing', Ifgrp Type 'lacp' fail 'default'
         Ifgrp Status   Broke   Addr_set
        lag_inactive:
        e3a: state lag_inactive, since 02Mar2016 11:20:31 (00:00:23)
                mediatype: auto-10g_sr-fd-up
                flags: disabling
                input packets 570514562, input bytes 37226372020
                input lacp packets 5149, output lacp packets 28527987
                output packets 28527983, output bytes 3537469892
                up indications 12, broken indications 6
                drops (if) 0, drops (link) 0
                indication: lag_inactive at 02Mar2016 11:20:31
                        consecutive 0, transitions 21
        e2a: state lag_inactive, since 02Mar2016 11:20:31 (00:00:23)
                mediatype: auto-10g_twinax-fd-up
                flags: disabling
                input packets 652053110, input bytes 42140000964
                input lacp packets 0, output lacp packets 28522282
                output packets 28522282, output bytes 3536762968
                up indications 9, broken indications 5
                        consecutive 0, transitions 18
can any one help me plz?
1 REPLY 1
hariprak
Hi,
This indicates the storage controller and the switch have not agreed upon something associated with LACP. Once the storage controller decides that LACP does not support using this port, the link is marked lag_inactive, indicating the link is not 'active' in the 'lag' (Link Aggregation Group).
For more details refer KB article https://kb.netapp.com/support/index?page=content&id=3013774
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
