ONTAP Hardware
reassign hot spares that is own by filer2 to filer 1
newbeee
any one here know whats the command?
Apprehsiate your help
1 REPLY 1
asulliva
You'll need to remove ownership, then reassign it.  Note that removing ownership for a disk in an aggr will cause it to treat it like a disk is lost, so be careful.
cDOT:
storage disk removeowner -disk <disk.id>
storage disk assign -disk <disk.id> -owner <node>
7-mode:
disk remove_ownership <disk.id>
disk assign <disk.id>
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
