ONTAP Hardware
snmp max query
jensP
Hello ,
I have centreon servers to oversee my cluster. I have snmp queries every 10 minutes to retrieve informations such as volume size , inode , snapreserve .... .
some of my queries do not receive answers  .
if I increase the interval , the number of response is better.
my question is:
is there a parameter that limits the number of query ?
My cluster :
2 nodes FAS8020
dot 8.3.2
thx
1 ACCEPTED SOLUTION
Jeff_Yao
personally i dont think there's this kind of number. but the output should depend on the filer's processing ability. so pulling too much data in very short interval might cause performance affection. in  general, i think 30min or 1 hour should be good interval to start from.
hopefully helps
thanks
1 REPLY 1
Jeff_Yao
hopefully helps
thanks
