Is there a way to extract snapshot delta information through OM?
emanuel
Hello all
I am curious if in operations manager if there is a graph version hiding somewhere that can show snap deltas from hourlys, nightlys, and weeklys ( ex: between hourly.0 and .1, weekly.1 and weekly.2 ) ?
or is there a way to grab the raw data and import it into an excel; like writing a custom report and dumping raw data?
Emanuel
2 REPLIES 2
smoot
No, there's not a graph. The problem is, if a volume has, say, 30 snapshots, for which two would we compute the delta?
There is a graph showing the long-term data overwrite rate (which, IIRC, computes snap delta between the oldest and most recent snapshots). Does that help?
Finally, from a volume details page, you can manually select two snapshots and compute the delta. I don't know if that's available from the CLI.
adaikkap
Its Volume Snapshot Details page that too when view at an individual volume level and not at filer/group levels.
You can use the dfpm dataset snapshot reclaimable cli.Its works for even for volumes which are not part of a dataset.
The only cavet is that you will need Provisioning Manager license.
[root@lnx]#  dfpm dataset snapshot reclaimable help
NAME
    reclaimable -- compute space reclaimable from deleting snapshots in a volume
SYNOPSIS
    dfpm dataset snapshot reclaimable <volume-name-or-id> <snapshot-name-or-id>
        [ <snapshot-name-or-id> ... ]
DESCRIPTION
    Compute space that can be reclaimed if the specified
    set of snapshots are deleted from the given volume.
[root@lnx]#
Regards
adai
