Software Development Kit (SDK) and API Discussions
cant connect to DFM 6.3rc1 using SDK 5.4 c#
stephen2
All, unable to connect to DFM. Have tried 2 DFM servers, admin user, database user. Connection fails.
Anyone know what I am doing wrong? Code sample below:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using NetApp.Manage;
namespace NetApp.NMSDK.Example
    class ApiClient
        static void Main(string[] args)
            try
                NaServer s = new NaServer("10.97.94.50", 1, 0);
                s.ServerType = NaServer.SERVER_TYPE.DFM;
                s.TransportType = NaServer.TRANSPORT_TYPE.HTTPS;
                s.Port = 8488;
                s.Style = NaServer.AUTH_STYLE.LOGIN_PASSWORD;
                s.SetAdminUser("admin", "admin123");
                NaElement api = new NaElement("cluster-iter");
                api.AddNewChild("max-records", "20");
                api.AddNewChild("resource-filter", "<resource-filter>");
                api.AddNewChild("tag", "<tag>");
                NaElement xo = s.InvokeElem(api);
                Console.WriteLine(xo.ToPrettyString(""));
            catch (NaAuthException e)
                Console.Error.WriteLine("Authorization Failed: " + e.Message);
            catch (NaApiFailedException e)
                Console.Error.WriteLine("API FAILED: " + e.Message);
            catch (Exception e)
                Console.Error.WriteLine(e.Message);
3 REPLIES 3
Navtej
Use port number 443
stephen2
I tried using 443 - I was just also trying port 80 to see if it made a difference
John_Roden
I have been connecting via perl pretty successfully... here is what I set when connecting OCUM.
my $s = new NaServer($server, 1 , 0);
$s->set_server_type('OCUM');
$s->set_transport_type('HTTPS');
$s->set_port(443);
I had issues in the beginning and played around with set_hostname_verification and got it to work, but I pulled that out recently and everything works fine.
