VMware Solutions Discussions
Fibre channel fas2050 during migration of data.
gemwoerden
Hello all,
I have no clue if this is the right place for a question like this, the community forum is a complete mistery to me
We have a fas 2050 with a single controller with these adapters :
Slot:            0a
Description:     Fibre Channel Host Adapter 0a (QLogic 2432 rev. 2)
Firmware Rev:    4.5.2
FC Node Name:    5:00a:098000:031777
FC Packet Size:  2048
Link Data Rate:  2 Gbit
SRAM Parity:     Yes
External GBIC:   No
State:           Enabled
In Use:          Yes
Redundant:       Yes
Slot:            0b
Description:     Fibre Channel Host Adapter 0b (QLogic 2432 rev. 2)
Firmware Rev:    4.5.2
FC Node Name:    5:00a:098100:031777
SRAM Parity:     Yes
External GBIC:   No
State:           Enabled
In Use:          Yes
Redundant:       Yes
Slot:            0c
Description:     SAS Host Adapter 0c (LSI Logic 1068E rev. B2)
Firmware Rev:    1.26.03.00
Base WWN:        f:080cb1:f300000:00
State:           Enabled
In Use:          Yes
Redundant:       No
Phy State:       [0] Enabled, 3.0Gb/s (9)
                 [1] Enabled, 3.0Gb/s (9)
                 [2] Enabled, 3.0Gb/s (9)
                 [3] Enabled, 3.0Gb/s (9)
Slot:            0e
Description:     IDE Host Adapter 0e
The fibre is connected to an external cabinet.
Can we use the fibre ports for data migration, for example break redundancy and use one of the two fibre ports for data migration? Is 2gbit the limit of these ports?
Thanks for your time!
1 ACCEPTED SOLUTION
aborzenkov
You still do not give enough information.
If your “data” is in form of LUN on NetApp, it may be possible using external data migration appliances (or even just host based tools). Or it may be possible using third party storage capabilities (like EMC CLARiiON SanCopy).
If your “data” is in form of files on NetApp volumes which are accessed via NFS/CIFS - it is not possible.
4 REPLIES 4
aborzenkov
Onboard FC ports in FAS2050 are 4Gb/s.
Could you explain what you mean under “data migration”. Migration from where to where?
gemwoerden
I want to hook up the fas 2050 to our brocade fibre channel switch and then hook it up to one of our esx servers. From there i want to migrate the data to another storage system.
aborzenkov
gemwoerden
We do use NFS volumes, and therefor cannot use FC for migration. We are now thinking of adding a 10gbe network card to the fas2050 for migration purposes.
