VMware Solutions Discussions
Reclaim space does not work in vsc
thor1887
Hello,
we try to reclaim space using the vsc.
It is not working and it always terminates with the error unknown,
as you see in the attached screenshot.
It would be nice to know if anybody succeeds using this feature and if you have any suggestion how to debug it.
Regards,
Thorsten
2 REPLIES 2
Jeff_Yao
VSC could be used to reclaim space ONLY from NFS-based VMs with prerequisites
below 2 kbs might be helpful
Unable to use the ESX reclaim/unmap function on a thin provisioned LUN - https://kb.netapp.com/support/index?page=content&id=2018575&locale=en_US
What VAAI configurations are supported on Data ONTAP storage controllers? - https://kb.netapp.com/support/index?page=content&id=3013572
thor1887
Hi yaoguang,
yes we are using a nfs datastore and no lun
so it has to work but it doesn't.
Thanks a lot for your reply,
Regards,
Thorsten
