VMware Solutions Discussions
SMVI 2.0 - fails when performing a restore of vmfs volume
daniel_kaiser
Hi,
Hopefully someone can shed some light on the issue we're having.  I'm able to use SMVI to backup NFS and VMFS datatstores/VM machines, but when I do a restore of a VM machine on a VMFS datastore it fails.  No restore issues with VM machines that are hosted on NFS, just VMFS.
We're running the following in our environment
OnTap 7.3.2
SnapManager for Virtual Infrastructure 2.0 (installed on vCenter server)
vSphere 4.0 w/update 1
Messages in the Task pane of SMVI
One or more mount requests did not succeed.  Please check vSphere Client for any error messages.
Failure in DatastoreMountAction:  One or more mount requests did not succeed.  Please check vSphere for any error messages.
Operation transitioning to abort due to prior failure.
Operation aborted.
Operation failed:  One or more mount requests did not succeed.  Please check vSphere Client for any error messages.
Messages in the Recent Tasks of vCenter Client
Rescan all HBA
Rescan VMFS
I see these two actions in the vCenter client when i submit the restore job.
Any help would greatly be appreciated.  Thanks.
1 ACCEPTED SOLUTION
amritad
Hi
Is ALUA enabled? Also are you able to see the datastore name properly in the inventory tab?
Regards
Amrita
14 REPLIES 14
daniel_kaiser
I noticed that a new Igroup was created called ESXhostname_smvidg_fcp and i assume this was created during the failed restore process.  The igroup settings appear to be identical to the Igroup we created for ESX.
wodgersmith
Did you get anywhere with this?
I am having the same issue. The backup seems to work fine and I can see the snapshot tasks appearing in the Virtual Center recent tasks but I see nothing when I try and mount the SNAP for restore.
I get a message that the Mount Request failed and to check the VSphere Client logs, however there is nothing reaching the VSphere client??
amritad
Hi
Is this an NFS datastore or a VMFS datastore that you're trying to mount? An NFS datastore mount operation would require FlexClone to be licensed.
REgards
Amrita
eric_barlier
Daniel,
what licenses have you got on this controller? I think NFS and SMVI requires a flexclone license. I know we had an issue where NTAP had to
issue us with a license to make SMVI and NFS work. Im pretty sure its flexclone but not 100% sure.
Eric
ogra
Hi,
Also check if you running VMFS over iSCSI the connectivity.
You might not able to reach the ESX server to mount the backup for restoration.
To isolate the Problem, simply try mounting the backup directly.
Cheers !!!
amritad
Hi
Flexclone licesnse is required for:
1) NFS datastore mounts
2)NFS VMDK restore to an alternate datastore
3)Single file restore
Backups and restores will not fail for other scenarios.
Regards
Amrita
daniel_kaiser
All,
We're running the controllers in an active/active environment and have flexclone licensed on both controllers.  The VMFS volumes are over Fibre Channel and no iSCSi is used in our environment.  Could the issue be somewhere on the fibre channel/switch configuration?  Thanks again for all your suggestions and please keep it coming.
keitha
Which ESX host are you selecting when you do the VM restore? Does that ESX server have access to the same FC LUN as the VM was backed up from? What will happen is SMVI will FlexClone the backup then connect the FlexCone to the ESX server you give it, then copy the VM from the FlexClone to the source VMFS. Thus it needs access to both the FlexClone and the original VMFS LUN.
Keith
daniel_kaiser
In the 'ESX Host ID' field, I'm selecting the same esx server that I backed up in the backup job.
amritad
Hi
Regards
Amrita
daniel_kaiser
Yes we have ALUA enabled and I can see the datastore that i want backed up in the datastore.
amritad
Hi,
So there is a releae note for ALUA enabled LUNs. so this isn't applicable right?
SnapManager for Virtual Infrastructure sometimes cannot
see datastores from LUNs mapped to ALUA-enabled
initiator groups
When you click Backup or Inventory in the SnapManager for Virtual Infrastructure user interface,
some datastores might be missing. These datastores are from LUNs mapped to ALUA-enabled
initiator groups.
Workaround:
Rescan all HBAs from each ESX host and then reopen the SnapManager for Virtual
Infrastructure user interface.
Regards
Amrita
daniel_kaiser
My specific issue has been resolved with the installation of SMVI 2.0P1D1.
http://now.netapp.com/NOW/download/software/snapmanager_vi/2.0P1D1/
SnapManager for Virtual Infrastructure - 2.0P1D1
Date Posted: 06-APR-2010
SnapManager for Virtual Infrastructure 2.0P1D1
04/05/2010
Bugs fixed in this release:
2.0P1D1
388092:  High CPU utilization
405310: Null Pointer Exception when SMVI cannot properly track a vCenter task
387359:  Failure in MountCloneSetupTaskWrapper
403263 : Retry VMware quiesced snap, then force non-quiesced snapshot if quiesced VMware quiesced snapshot fails
2.0P1
383747 - HostLunMapper should check the transport type instead of just casting it and hoping
380467 - SMVI restore operation causes duplicate entrys in /etc/exports
390010 - ApplyRetention deletes recent snapshot if expected snapshot is missing
392529 - If vCenter returns a null reference for a request to get a VM's UUID, SMVI does not          check the response appropriately
393240 - VmSnapshotDeleteAction: java.lang.reflect.UndeclaredThrowableException
375255 - SMVI unable to mount a datastore; mount operation fails!
379489 - SQLException is thrown and causes SMVI operation to fail
oosterbaan
We seem to have the exact same problems, but installing the P1D1 version generates a 'invalid service name' error about some openSCmanager service and a few other error messages.
did you install anything prior to this p1d1 version?
