VMware Solutions Discussions
SMVI FLOW-11019 Failure in VMgetVirtualMachineList
christianmaier
Hello,
i use the new virtual storage console 2.0 with integrated smvi 3.0 version
when i try to us a single file restore the wizard crashes wit the error
FLOW-11019 Failure in VMgetVirtualMachineList: Did not find any VM.
some ideas....
Thanks
Chris
13 REPLIES 13
amritad
Hi
Are you able to create an SFR session successfully? Do you see the VM listed in the drop down menu?
Regards
Amrita
christianmaier
Hi,
no, i can not see any VM´s when i try the SFR, the vm list is empty.
Normal Restores are woking fine only th SFR makes trouble.
Thanks
Chris
amritad
Are you able to manually enter the VM names and create a session?
Regards
Amrita
christianmaier
mhhh,
i havent try this at the time, but i will check this out today.
Thanks
Chris
amritad
CAn you also check if there are registered VMs in the datastore?
Regards
Amrita
christianmaier
when i manually enter der VM name the SFR works.
All vm´s are registered in the datatsores.
Regards
Chris
amritad
That's good to know. IS there a distributed vSwitch in your environment?
Regards
Amrita
roland_kurz
Hi together,
the problem is that vsc 2.0 SFR only browse the root of the registered vm´s.
If you had created folders and move all vm´s and templates in folders there is nothing in the listbox.
Christian, please move for testing SFR the source vm and the destination vm for testing out from your vm folder in the root and then you will see the two vm´s in the listbox
Netapp (Amritad), please correct this bug. Please browse not only the root, browse also the customer created vm-folders.
Thanks
Bye
amritad
Yes we did see this issue. Would it be possible to also file a support case for this? That would really help us process this faster.
Regards
Amrita
roland_kurz
Hello Amrita,
i created a case for that: Case # 2001613158
Thanks for fixing this issue
Bye
Roland Kurz
Tel. Crailsheimer Straße
52
Fax: D-74523 Schwäbisch
Hall
amritad
Thanks Roland
Regards
Amrita
cbaertsch09
Hello Roland
Did you already get an answer from NetApp. I just tested it with VSC 2.1 and I'm still getting the error "FLOW-11019 Failure in VMgetVirtualMachineList: Did not find any VM". As soon as I move my VM to the root directory of my vCenter it works.
Cheers
Chris
proactsupportnl
Hi all,
this is now fixed in VSC2.1.2 according to NetApp. This was known as bug 437901. Release notes state this should be fixed. My customer is going to install this version soon. If i get feedback, I will post that here too.
