VMware Solutions Discussions
Snap Drive port numbers
VAIBHAVMISHRA
Hi Experts,
Need your suggestions:
I have found a complete list of ports that needs to play with if need to connect snapdrive to storage box and snapdrive to ESX Virtual Centre. My question is that if I need to install SD (SnapDrive) on physical servers, which are the minimum ports required to open. My objective is that I am installing SD on many VM as well as on physical servers so which are minimum ports required to open. I also use Operation Manager.
List of ports:
  1. 137       - Netbios-ns
  2. 138       - Netbios-dgm
  3. 139       - Netbios-ssn
  4. 443       - HTTPS
  5. 80         - HTTP
  6. 8088     - HTTP for Operation Manager
  7. 8488     - HTTPS for Operation Manager
  8. 808       - Snapdrive Webservices
  9. 4094     - Snapdrive Webservice HTTP
  10. 4095     - Snapdrive Webservice HTTPS
Thanks,
Vaibhav
2 REPLIES 2
crocker
Hi,
Since you have not gotten an answer, you may want to ask this question in the NetApp Support Community.  The current customers, partners and internal Subject Matter Experts are addressing technical product questions there.
Mike
VAIBHAVMISHRA
