VMware Solutions Discussions
100 % CPU and Memory when starting NetApp VSC Service
stuarty1874
Hello,  below is the problem we have...
- Sername: VMwareUTIL
- o/s: w2k8.R2.SP1
- vCPU: 2
- RAM: 8GB
- Platform: virtual machine
- Apps: NetApp VSC 2.1
- Apps: VMware Update Manager 4.1
NetApp VSC service runs under LOCAL SYSTEM.
- Servername: VMwarevCenter
- o/s: w2k8.R2.SP1
- vCPU: 2
- RAM: 8GB
- Apps: vCenter 4.1
Up until last Saturday the vCenter VM was running with w2k3.R2.SP2.  Everything was working fine.
We upgraded \ replaced the w2k3.R2.SP2 vCenter server with w2k8.R2.SP1.  Everything worked for a few days then when we rebooted the VMwareUTIL VM.
Now the NetApp VSC JAVA process takes all the resources and kills the VMwareUTIL VM.  We see almost 100 % CPU and RAM and have trouble enabling the NetApp VSC plugin.
Anyone seen anything like this?
2 REPLIES 2
radek_kubka
Hi and welcome to the Community!
Yes, I've seen exactly the same behaviour in a lab environment on w2k8 server. Quite often I had to kill the offending process via task manager & then everything worked fine again.
VSC 2.1.1 is out - maybe it is worth checking whether it fixes the problem?
Regards,
Radek
stuarty1874
Thanks Radek.  Just waiting on NetApp support calling us back.
I haven't tried to upgrade to VSC 2.1.1 yet.  Will discuss that with the tech and let you know
