Network and Storage Protocols
Issue with sftp accessed by local users in /etc/passwd
khcchen
Hi all,
I am having issue to access  /etc folder using SFTP for adminitration purpose.
The controller is runing 7-mode 8.1.4p1 with NFS licensed and I used the following page as guidance
https://kb.netapp.com/support/index?page=content&id=1012617
However, when I tried to connect to the controller by WinSCP/Filezilla, the storage console returned the following messages, and then SFTP connection creation failed.
[controller01: sshd_1:error]: error: Disconnecting: SFTP connection creation failed
[controller01:sftp.connection.setup.failed:error]: SFTP (SSH File Transfer Protocol) connection (#72) from client system xx.xx.xx.xx, user sftpuser failed. Reason: Homedir not set
In /etc/passwd, I have created a new sftpuser and specified the the homedirectory  /etc:
Also checked by getXXbyYY getpwbyname_r
pw_dir = /etc
sftp settings..
options sftp.auth_style unix
options sftp.dir_override (null)
options sftp.enable on
ssh.enable on
ssh1.enable off
ssh2.enable on
All other controllers are working...except this one, I tried to compare the settings, re-configured SFTP, created new sftp users, sftp.dir_override directory, but none of them works.
Thanks in advanced.
6 REPLIES 6
aborzenkov
What is in your nsswitch.conf? Is filer set to uset /etc/passwd for users and in which order?
khcchen
Hi aborzenkov,
rdfile /etc/nsswitch.conf
hosts: files        nis    dns
passwd: files     nis    ldap
netgroup: files  nis   ldap
shadow: files     nis
rwelshman
I think the home directory should be set to /vol/vol0/etc  ?
khcchen
Hi rwelshman
I tried different paths in the /etc/passwd file under different user names..but unfortunately...all failed
/etc
/vol/vol0/etc
rwelshman
have you tried setting the sftp.dir_override option to /vol/vol0/etc?
khcchen
I tried the following settings, but all failed.
sftp.dir_override           /
sftp.dir_override           /vol
sftp.dir_override           /vol/vol0
sftp.dir_override           /vol/vol0/etc
Done further checking on the sftp log (/etc/log/sftp.cmd), it seems like the path is set to /vol/vol0, instead of  /vol/vol0/etc
Ptype          SSH_FXP_INIT Version 3
Ptype SSH_FXP_REALPATH Id 256 Path /vol/vol0
Did I miss anything?
