Network and Storage Protocols
Question about Netapp Simulator 8.1 C-Mode
schildjo1
Hello Community,
first of all I am new to NetApp.
I try to set up a pNFS environment. Therefore i installed Netapp Simlator 8.1 C-Mode and used the Document "Parallel Network File System Configuration and Best Practices for Data ONTAP 8.1 Cluster-Mode (TR-4063) https://communities.netapp.com/docs/DOC-16613 .
Everything works fine till i try to verify my setup (7.1 Enable pNFS on Vserver)
simcluster::*> nfs show -vserver nfsvsrv1
                                          Vserver: nfsvsrv1
                               General NFS Access: true
            RPC GSS Context Cache High Water Mark: 0
                             RPC GSS Context Idle: 0
                                           NFS v2: disabled
                                           NFS v3: enabled
                                         NFS v4.0: enabled
                                     UDP Protocol: enabled
                                     TCP Protocol: enabled
                              Spin Authentication: disabled
                             Default Windows User: -
                      Enable NFSv3 EJUKEBOX error: false
Require All NFSv3 Reads to Return Read Attributes: false
Show Change in FSID as NFSv3 Clients Traverse Filesystems: enabled
Enable the Dropping of a Connection When an NFSv3 Request is Dropped: enabled
               Vserver NTFS Unix Security Options: use_export_policy
                    Vserver Change Ownership Mode: use_export_policy
           Force Usage of SpinNp Readdir Requests: false
                       NFS Response Trace Enabled: false
                   NFS Response Trigger (in secs): 60
                        UDP Maximum Transfer Size: 32768
                        TCP Maximum Transfer Size: 65536
                      NFSv3 TCP Maximum Read Size: 65536
                     NFSv3 TCP Maximum Write Size: 65536
                              NFSv4.0 ACL Support: disabled
                  NFSv4.0 Read Delegation Support: disabled
                 NFSv4.0 Write Delegation Support: disabled
Show Change in FSID as NFSv4 Clients Traverse Filesystems: enabled
                         NFSv4.0 Referral Support: disabled
                          NFSv4 ID Mapping Domain: mic.science-computing.de
NFSv4 Validate UTF-8 Encoding of Symbolic Link Data: disabled
              NFSv4 Lease Timeout Value (in secs): 30
              NFSv4 Grace Timeout Value (in secs): 45
                Preserves and Modifies NFSv4 ACL : enabled
                    NFSv4.1 Minor Version Support: enabled
                                    Rquota Enable: disabled
                 NFSv4.1 Implementation ID Domain: defaultv41impliddomain.com
                   NFSv4.1 Implementation ID Name: defaultv41implidname
                   NFSv4.1 Implementation ID Date: Thu Jan 01 00:00:00 1970
                     NFSv4.1 Parallel NFS Support: enabled
                        NFSv4.0 Migration Support: disabled
                         NFSv4.1 Referral Support: disabled
                        NFSv4.1 Migration Support: disabled
                              NFSv4.1 ACL Support: disabled
                             NFS vStorage Support: disabled
              NFSv4 support for Numeric Owner IDs: enabled
On 7.3 "Check the Status of pNFS on Cluster-Mode" i try to enter the following command: "statistics show -object nfsv4_1 -instance nfsvsrv1 -counter *_total.
But here begins my problem. I have no Option nfsv4_1 only nfs4 is available. Is this a limitation of the simulator?  The same happens to the option -counter. There is no such option on my simulator...
Any help would be appreciated.
Thanks  in advance
Best Regards
Johannes
2 REPLIES 2
scottgelb
The official pnfs is 8.1.1 I think. But you may find it in advanced mode Or diag mode in the current vsim 8.1 "set -priv advanced"
Hi Scott,
thanks for the hint. Now i have an option _counter. But if i try statistics show -object nfs4 -instance nfsvsrv1 -counter * i got no result.
I think this happens because of the nfs4 in my command and not nfsv4_1 mentioned in the text...
Any ideas whats  wrong?
Best Regards
Johannes
