ONTAP Discussions
Thick and Thin provisioning diffenence
Rawat_Sunil
What is Thick and Thin provisioning and how they configure in volume.
Regards,
Sunil Rawat
1 ACCEPTED SOLUTION
JGPSHNTAP
Not to be rude, but it sounds like you need to understand the basic fundamental commands.
Please try to take the web training classes that will help you out.
 I will get you started on this one.. assuming this is 7-mode as in your tag, you can look  - vol status (look for guarantee)
But please review some web based training
8 REPLIES 8
Renifa
Hi,
Thick provisioning for volumes
When a thick-provisioned volume is created, Data ONTAP sets aside enough storage from the aggregate to ensure that any block in the volume can be written to at any time. When you configure a volume to use thick provisioning, you can employ any of the Data ONTAP storage efficiency capabilities, such as compression and deduplication, to offset the larger upfront storage requirements.
Thin provisioning for volumes
When a thinly provisioned volume is created, Data ONTAP does not reserve any extra space when the volume is created. As data is written to the volume, the volume requests the storage it needs from the aggregate to accommodate the write operation. Using thin-provisioned volumes enables you to overcommit your aggregate, which introduces the possibility of the volume not being able to secure the space it needs when the aggregate runs out of free space.
Check the following link for more info:
https://library.netapp.com/ecmdocs/ECMP12458215/html/GUID-2F5C9474-FFE9-4E59-84DB-1B9D6D134688.html
Thanks,
Renifa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Rawat_Sunil
Dear Renifa,
Thanks for your support.
It would be great if you will share the command/process for creatimng the thin and thick volume/LUN
Regards,
SUnil Rawat
JGPSHNTAP
Rawat_Sunil
No,
I knew it, just looking for some other options for lun provisioning in VMWara.
sharing the command:
Volume provisioning (new volume):
vol create flexvol_name aggr_name –s [volume|file|none] size [k|m|g|t]
Creates a FlexVol volume with the specified space guarantee type (volume, file, or none) and the desired size of the guaranteed space (KB, MB, GB, or TB).
To use volume thin provisioning set guarantee to ―none.‖
To use volume thin provisioning but allow individual LUNs to reserve space at the aggregate level (for LUN-level thick provisioning) set guarantee to ―file.‖
To use volume thick provisioning set guarantee to ―volume.‖
Volume provisioning (existing volume):
vol options flexvol_name aggr_name guarantee [volume|file|none]
Changes the space guarantee setting of an existing FlexVol volume.
Regards,
Sunil Rawat
Renifa
Hey Rawat,
Looks like you got the commands to create the Thick/Thin LUN. Do let us Know if you need further help.
Renifa.
Rawat_Sunil
Dear Jgpshntap
VijayaBhaskarReddy
Not a web-based training as such, but TR-3965 has some excellant information about this topic.
http://www.netapp.com/us/media/tr-3965.pdf
RANJBASSI
Have you tried the NetApp learning centre. I think you need to a valid NetApp account but there a number of courses on there which are free.
https://netapp.sabanow.net/Saba/sabasso.jsp
