Don't have an account?
ONTAP Hardware
The FAS2240-4 comes with four power supplies. If three of them fail for some reason, can the system run on just the one remaining power supply?
Solved! See The Solution
No. It needs at least two PSU providing power. It also needs all four PSU fans; physically removing PSU will cause shutdown after 2 minutes.
they require a minimum of one per controller/per shelf. Anything less and they will shut down
NetApp has been presented with a Silver Stevie® Award in the Award for Innovation in Customer Service - Computer Industries category in the 18th annual Stevie Awards for Sales & Customer Service.
Did you know you can receive a notification when new software releases are published to the NetApp Support Site?
