ONTAP Hardware
Connecting to FAS 3170
solvire
I picked up a FAS3170 and for the life of me can't seem to get onto the controllers.
I tried a serial connector from MAC USB and only get blank screen so I am obviosly doing something wrong. I tried two adapters so I am not sure what I am doing there. I tried the serial.app from decisivetactics.com to see if a gui could help me but failed with that one as well.
I plugged the management ports into the switch and tried to hit the default IP addresses
Management Port Controller AController B
1192.168.128.101192.168.128.102
2192.168.129.101192.168.129.102
They didn't respond at all.
Maybe the previous owner didn't reset anything.
Can the networking settings be reset?
Pardon my lack of knowledge on this topic, but I am stuck.
1 ACCEPTED SOLUTION
aborzenkov
NetApp does not have any default IP; not sure where you got them from, nor what ports 1 and 2 mean.
Are you sure you are using correct ports and cables. I have no issues using e.g. Cisco console cable with two different USB-to-serial adapters and PuTTY. You need to use 9600, 8 bits, no parity, no flow control.
What ports do you connect to?
2 REPLIES 2
aborzenkov
solvire
Thanks for the response.
I tried 3 different brands and finally got one that worked.
I'm using the plugable brand db9 to USB adapter and Serial.app.
For anyone who wants to know this might save a few trips to radio shed.
http://plugable.com/products/pl2303-db9
9600 baud and vt100 display. That got me in there.
I pulled the default IP addresses from:
https://kb.netapp.com/support/index?page=content&id=3013407&impressions=false
I guess it's e-series but figured the FAS model would be the same.
I got in eventually so I guess this is closed down.
Cheers!
