ONTAP Hardware
FAS2040HA + 2x DS14mk2 + 1x DS4243: is it supported?
neves_jacques
Good Morning,
Is It supported to connect on a FAS2040HA, 2x DS14mk2 and 1x DS4243 in order to move the data between the DS14mk2 / DS4243?
I don't see this configuration on the document "Configuration Rules and Examples for FAS20xx Systems" (215-03642_D0.pdf).
I wish to move the date from the aggregate on the 2x DS14mk2 to a new aggregate on the 1x DS4243.
I plan to remove the 2x DS14mk2 after the migration on the DS4243.
Thanks in advance for your feedback.
Regards,
JNV
1 ACCEPTED SOLUTION
baijulal
DS4243 needed to attached to SAS port and  DS14mk2 (2 in one stack)to the FC port on the contoller.
It should work.
2 REPLIES 2
baijulal
It should work.
neves_jacques
Thanks 😉
I have just done the intervention and it works.
Regards,
JNV
