ONTAP Hardware
SP upgrade - unzip failed
rozle_palcar
Hello,
We have to upgrade SP modules on V3210 HA system at customer. Since machine is in takeover mode I can't upgrade both SP modules over DOT, so I have to use 'sp update <link>' command from SP prompt. When I execute command I get error about unzip:
SP netapp2> sp update http://www.osap.si/tmp/308-02139_A0_1.3_SP_FW.tar.gz
Downloading package...
Uncompressing package...
FW package unzip failed.....FAILED
Cleaning up...
ERROR : SP FW Update Unsuccessful.
I tried to upload firmware package on FTP with few different clients (in case problem would be corrupted file) but it is the same. Also I tried to upgrade to lower versions of SP but I receive the same error... For files with *.zip extension it reports that file-type is not correct.
Probably there is problem because version of SP module is ancient (1.0.1) but that does not change the fact that I have to upgrade it
SP netapp2> sp status
Firmware Version:     1.0.1
Mgmt MAC Address:     00:A0:98:13:C0:2C
Do you have any idea how could I upgrade SP module over http? Thank you in advance!
Best regards,
Rozle
2 REPLIES 2
mharding
Hello - Did you check the Upgrade Guides from the support site - they address Service Processor upgrades?  If that doesn't help, and if you're not getting an answer, try opening a support ticket.
BISHTECHIT
Hello -
Try this
[copy SP update file to NAS -> etc$ -> software ...rename to SP_FW.zip]
Run ---
software install SP_FW.zip
sp update
sp status
