ONTAP Hardware
Shelf Capacity
jackaguilar
Hi!
Is there any way to know how many disks are installed in a shelf, the capacity of disk/shelf per controller?
Thanks!
1 REPLY 1
MarcSchindler
Hi,
Do you mean from a installed system or from a system which you plan to buy ?
" from a installed system"
-> System Manager (GUI oder Webinterface in 8.3)
"from a system which you plan to buy"
-> Tools like Synergy
- It depends on the version of ONTAP
- How much Spares to you need
- With or without disk partitioning
- Which Shelf type and which disk format
A list of our shelfs with details:
http://www.netapp.com/us/products/storage-systems/disk-shelves-and-storage-media/disk-shelves-tech-specs.aspx
