ONTAP Hardware
Vseries panic with Native Disks
JOEYNGUYENHP
i have a fresh brand new vseries 3240 in my lab.
i pulled a shelf of ds14mk2AT from another decomm filer and connected to the vseries.
when booting up the vseries, trying to enter maintenance mode but the vseries panic.
Tue May 22 07:24:01 GMT [fci.adapter.link.online:info]: Fibre Channel adapter 3d link online.
Tue May 22 07:24:01 GMT [fci.adapter.link.online:info]: Fibre Channel adapter 0c link online.
Tue May 22 07:24:07 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 3a.
Tue May 22 07:24:07 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 3b.
Tue May 22 07:24:07 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 3c.
Tue May 22 07:24:08 GMT [fci.initialization.failed:error]: Initialization failed on Fibre Channel adapter 0d.
PANIC: sanown: received add for already known disk
version: NetApp Release 8.0.3: Thu Mar 29 22:27:55 PDT 2012
cpuid = 0
Uptime: 1m21s
coredump: primary dumper unavailable.
coredump: trying secondary dumper...
no tftp server ip specified
netdump: no targets available to dump
coredump: secondary dumper failed -1.
Logging shutdown event to the SP...
System halting...
cpu_reset called on cpu#0
how can i remove the disk ownership if i can get into maintenance mode? i tried reading the pdf -
V-Series Systems
Implementation Guide for Native Disk Shelves
but nothing in there has what im looking for
thanks
joey
1 ACCEPTED SOLUTION
isaacs
Hi Joey,
You need to set the "fc-non-array-adapter-list" environment variable when using multipath-ha cabling on FC disk shelves.
From the LOADER> prompt, if using ports 0d and 3c:
LOADER>setenv fc-non-array-adapter-list 0d, 3c
LOADER>boot_ontap
That should take care of it!
- Dan
2 REPLIES 2
isaacs
Hi Joey,
LOADER>boot_ontap
- Dan
JOEYNGUYENHP
that did the trick! thanks Daniel
