ONTAP Hardware
add 15K RPM disks to a volume that has 10K disks
prakash_aviva
Hi,
Ww have a FAS 270 filer with DO 7.0.1 and we need more disks to add to the filer.
Can we add 15k RPM disks to a volume that has 10k disks ?
I know this is available in current product (though not recommended), just want to be sure for FAS270.
Please suggest.
3 REPLIES 3
NETAPPCYP
Yes it possible and yes you're right not recommended, but now days with only 15krpm disks available do we really have a choice , for these older systems.
Have a look at http://now.netapp.com/NOW/knowledge/docs/ontap/rel80/html/ontap/smg/GUID-BE0475EA-4BB1-4544-ADC8-B0EADAB6C2D3.html for various parameters.
Recommend you upgrade your DOT also a your lastest supported version is possible.
GL
prakash_aviva
Thanks.
But i do not see the options as mentioned in the link
pcnfsd.enable                off
pcnfsd.umask                 22
raid.background_disk_fw_update.enable on
raid.disk.copy.auto.enable   on
raid.media_scrub.enable      on
raid.media_scrub.rate        600
raid.media_scrub.spares.enable on
raid.reconstruct.perf_impact medium
raid.reconstruct.wafliron.enable on
raid.resync.perf_impact      medium
raid.scrub.duration          360
raid.scrub.enable            on
raid.scrub.perf_impact       low
raid.scrub.schedule
raid.timeout                 24
raid.verify.perf_impact      low
rlm.setup                    off
peter_lehmann
Hi Ranil
This is because of the rather old ontap version you are running. In order to get the new disks recognised, you will need to update at least the "disk qualification" file. I'd also recommend you to do a Ontap upgrade (which then includes the disk qualification). And also the options will appear with the new ontap.
Peter
