AFF
AFF200 Dual controller 8 disks
reinhartman
Hi
I am currently configuring a AFF200 system with 8 disk.
The system is configured with root-data partioning. I assigned all the data partiotions to 1 node:
AFF1-Cluster::*> aggr show-spare-disks
Original Owner: AFF1-Cluster-01
Pool0
Root-Data1-Data2 Partitioned Spares
Local Local
Data Root Physical
Disk Type Class RPM Checksum Usable Usable Size Status
1.0.0 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.1 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.2 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.3 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.4 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.5 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.6 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
1.0.7 SSD solid-state - block 678.5GB 0B 894.3GB zeroed
Now i want to create a single aggr, but i cant because the system cannot fine any spares:
The selected disk type that is assigned to node "AFF1-Cluster-01" has low spare disks. Add disks to the node or select another disk type.
I am stuck now. Can somebody try to point me in the right direction?
Thanks in advance.
Reinhart
2 REPLIES 2
reinhartman
This topic can be closed. It was a issue with the gui.
Thanks
Reinhart
potapius
А200 support root-data-data partitions, this is bettter in ters of perfomance and usage of disk space.
