AFF
AFF200 with vCenter 6.5
amatteo78
Hello,
I installed new AFF200, I connect it with VCSA 6.5. Now I create 1 Vol with 1TB LUN inside. Vol is deploy in thin and LUN with tick on space reservation. I move 1 vm about 200GB thick HDD inside.
Now on vCenter I can see datastore with 800GB available, meanwhile on AFF I can see only 60GB used. Maybe it real used space... becouse I see this different ?
Thanks
M.
1 REPLY 1
sgrant
Hi, did you ever get to the bottom of this?
I would suspect that with the AFF, since inline dedupe, compression and compaction are on by default, you are just seeing the result of all the efficiency savings. The output of DF -S would give you most of the the answer. For the compaction you will need to look at the Aggregate level Storage Efficiency output using the privilege advanced command aggr show-efficiency. Hopefully all those figures add up.
Hope it helps,
Grant.
