AFF
CriticalFruNotPresentAlert on New Installed A200 System
NetappNewbie-Roy
Hi Tech Guys,
My system shows the following error message after I install a A200 system. It shows a CriticalFruNotPresentAlert on the dashboard.
A200C::> system chassis fru show
Chassis ID          FRU        Type     State       Nodes Sharing the FRU
021710019376        A200C-02   controller
                                        degraded    A200C-02
021710019376        A200C-01   controller
                                        ok          A200C-01
021710019376        PSU1 FRU   psu      GOOD        A200C-01
021710019376        PSU2 FRU   psu      GOOD        A200C-01
021710019376        PSU1 FRU   psu      NOT_PRESENT A200C-02
021710019376        PSU2 FRU   psu      NOT_PRESENT A200C-02
6 entries were displayed.
Then about one day later, I check again and it becomes normal.
                                        ok          A200C-02
                                        ok          A200C-01
021710019376        PSU1 FRU   psu      GOOD        A200C-02, A200C-01
021710019376        PSU2 FRU   psu      GOOD        A200C-02, A200C-01
I would like to know what is the error about?
1 ACCEPTED SOLUTION
AlexDawson
If it happens again, I would suggest to call support, but as a once-off issue, this probably relates to startup of hardware management services.
1 REPLY 1
AlexDawson
