AFF
Difference between NetApp "0E" part and "Ad" part
Shubhankar
Can anyone please help me understand the difference between parts with "0E" and parts with "Ad", and why is there price difference. For Example : Part "E-X4119B-0E-C" and part "E-X4119B-AD-C".
Thanks in advance.
3 REPLIES 3
ttran
Hi Shubhankar,
Typically part "E-X4119B-0E-C" is used to discount the part when purchasing the drive in a bundle where "E-X4119B-AD-C" is used to buy individual drives afterward and has the full list price. Your account team can discuss pricing with you in further detail. From a technical perspective, both part numbers are identical.
Regards,
Team NetApp
Team NetApp
Shubhankar
Hello,
Thank you so much so the response, appreciate your help. I have a follow-up question, hope you can help me with the same.
Part "E-X4119B-0E-C" and "E-X4119B" also look similar,  the only difference being "-0E-C". Part "E-X4119B-0E-C" is being priced lower that part "E-X4119B".
So, when we build a configuration which part should be used "E-X4119B-0E-C" or "E-X4119B", and what is the difference between them.
Thanks in advance.
TMACMD
Same part. One is "-C"onfigured with the system the other is not.
Generally, the -C parts are less expensive as they are bundled with the controllers.
