AFF
EOL Product
SumitSolanki
Where I can see the EOL and EOS product on Netapp portal?
FAS 8020 and 2554
1 ACCEPTED SOLUTION
2 REPLIES 2
andris
If you might be referring to NetApp Hardware Universe, it maintains information concerning End of Support (EOS) hardware, as well. Just make sure you are not filtering them out in the UI.
Note: NetApp doesn't formally use the EOL term.
