AFF
Flash Cache: which volume is breaking it?
vladimirzhigulin
Hi,
I have a filer with 512Gb FlashCache, please have a look at the graph generated by Performance Manger.
Questions:
1. Is it ok / normal to have 60% hit rate?
2. How can I tell what volume causes spikes in "miss" ~ every hour? I can not match it against workload of any volume, again looking at PM graphs.
Thanks,
Vladimir
2 REPLIES 2
AGUMADAVALLI
use the following command at ontap prompt:
stats show -p flexscale-access
stats show ext_cache_obj
You will have a better understanding of how flexcache  is working.
thank you,
AK G
vladimirzhigulin
AK G,
Thanks, i know about these two. It doesn't tell you which volume triggers "Evict" .. this is what I'm really after.
Vladimir
