AFF
Flash Storage
Prashanth
How much of flash storage is required to built 1000 VDI machines.
Can these flash arrays be part of On cluster mode.
1 REPLY 1
mcramer
Hi there
If you are a NetApp partner you can use the VDI sizing tool that is part of the NetApp toolset available to you at https://spm.netapp.com
If you are a customer this is a perfect time to start a discussion with either your NetApp SE or partner technical resource to ensure that the correct solution is designed 🙂
Cheers
Marc
marc cramer | pre sales consultant | netapp new zealand
