AFF
Flash storage with XenDesktop
tparks21
Do you feel that Flash storage is necessary for a 200 user deployment of XenDesktop?
2 REPLIES 2
triantos
Maybe, maybe not. Context is important. While the number of users is certainly important their activity is critical to make that determination. For example, If these guys are developers they can generate an enourmous amount of IO. In fact, I was given a 300 users requirement for north of 7GB/s not too long ago. Yes, that is Gigabytes. So we need some more detail.
Thanks
Nick
isaacs
Hi,
The number of users is important, but just as important is the amount of IOPs required for each user.   Has that sizing been done?
Once the IOP requirements are set, acceptable latency levels need to be established.  Depending on the FAS model deemed most fitting for the workload, VST Flash  (FlashCache or FlashPool) may suffice.  But we can't really give a good answer until the sizing has been done.  If you need help with that, let us know!
Dan Isaacs
TME @ NetApp
All-Flash FAS (AFF)
FlexArray/V-Series
[email protected]
@danisaacs
