AFF
Have trouble creating an encrypted volume or converting volumes
stefonsamaroo
I have aFF a250 , i have an tier with one SVM and  a couple volumes , i set up  the keystore manager but i am unabled to create an encrypted volume. both in UI or Command line
node::*> volume create -vserver <svm> -volume test4 -aggregate aggr1 -size 12GB -encrypt true
Error: command failed: Internal error. Use the "cluster show" command to verify
that all nodes are healthy. Wait a few minutes and try the operation
again.
node::*> volume create -vserver <svm> -volume test4 -aggregate aggr1 -size 12GB -encrypt false
[Job 1182] Job succeeded: Successful
i see no encryption related errors and my cluster and node shows up healthy
1 ACCEPTED SOLUTION
chenguanghui
hello:
   For NVE, if you set , volumes you create with the and commands are automatically encrypted. For NVE (if it is set) cc-mode-enabled=yes, the volume will be automatically encrypted using the created volume create and volume move start commands. For volume create, there is no need to specify -encrypt true. I hope this article will help you.
https://docs.netapp.com/us-en/ontap/encryption-at-rest/enable-onboard-key-management-96-later-nve-task.html
Best regards.
2 REPLIES 2
TMACMD
Have you run “cluster show”? Is the cluster healthy?
 What about “ security key-manager onboard show-backup”?
you may want to try “security key-manager onboard sync” and enter the passphrase
chenguanghui
hello:
Best regards.
