AFF
SnapMirror Active Sync between AFF A-series and AFF C-series
Shaw_HM
According to the file
FAQ - SnapMirror active sync (SM-as) for ONTAP 9.15.1.pdf
"What are the supported platforms for SnapMirror active sync?
Answer: SM-as supports only two-node HA clusters, either AFF or ASA models. This includes A-Series
and C-Series. Both primary and secondary clusters must be the same type, either AFF or ASA. Protection
for business continuity involving FAS models is not supported."
So I want to know if the primary clusters is AFF C400 and secondary clusters is AFF A300, SM-as supports?
1 ACCEPTED SOLUTION
andris
The documentation for SnapMirror Active Sync clarifies that statement.
https://docs.netapp.com/us-en/ontap/snapmirror-active-sync/prerequisites-reference.html
Hardware
  • Only two-node HA clusters are supported.
  • Both clusters must be either AFF (A-Series and C-Series) or ASA (A-Series and C-Series). Mixing between AFF and ASA is not supported. Replication is supported between AFF A-Series and C-Series.
1 REPLY 1
andris
Hardware
