AFF
create an aggregate with ADP
AhmedAl-Batoosh
How to create an aggregate with ADP, since all the commands have to specify the number of disks, even in config builder
Iraq
1 ACCEPTED SOLUTION
TMACMD
Aff or fas? Adpv1 or apdv2?
 With fas / adpv1 it’s straight forward.
with aff / adpv2 just think of each partition as a disk
 if you are using aff, all SSDs should get partitioned by default in 9.14+.  If not review this article
https://kb.netapp.com/on-prem%2Fontap%2FOntap_OS%2FRAID_Issues%2FCONTAP-58445
 the disk must be owned and partitioned to be used correctly.
verify with
 storage aggregate show-spare-disks
command
 you should see the same disk on two nodes. One partition belongs to each node
1 REPLY 1
TMACMD
verify with
command
