AFF
fas2552 ssd issue
Faisal1981
Dear
one of my customers has fas2552 running on 4x 200gb ssd and other sas disk they shut down the storage and restarted as they want to shift their office but the storage ssd didnt come up and data cannot be accessed.
the storage is EOS and we replacement the SSD with new refurb ssd but still its same we need to know if there any solution customer can get access their data or there is not option other than destroy aggregation and creating the aggregation again
Waiting for your reply
regards
Faisal
3 REPLIES 3
TMACMD
Those SSD units are likely on 8-10 years old.
i just worked an upgrade with those. They had 48 failed SSD @200g. Not a thing you can do. They are old and were destined to fail at this point. Is you are replacing the SSD with “supported” third party drives (ie refurb!) make sure they are newer-ish models. The 100/200g units I’ve seen fail very predictably very quickly
SpindleNinja
Was it all of the SSDs?  There's a few 200GB drive models are affected by the below SU -
https://kb.netapp.com/Support_Bulletins/Customer_Bulletins/SU448
Faisal1981
Dear Spindleninja
thanks for your feedback so as per suggestion and recommendation we should not install SSD 200 gb as it more than 8 yrs old and will go with higher capacity like 800 / 400/ 960 ssd and if we get these hdds and install so do you think system wil back as it was before
waiting for your reply
regards
