AFF
flash cache
TDUBB1234
how can i tell if my system has the flash cache module installed?
7 REPLIES 7
pascalduk
It should be in the sysconfig output. E.g.:
        slot 8: Performance Acceleration Module II 512 GB
                         State:     Enabled
baijulal
If you find H/W installed make sure
License is applied (licese command) and options "flexscale.enable" is set to    on
TDUBB1234
options show
flexcache.access             none
flexcache.deleg.high_water   90
flexcache.deleg.low_water    50
flexcache.enable             off
flexcache.per_client_stats   on
flexscale.enable             on         (same value in local+partner recommended)
flexscale.lopri_blocks       off        (same value in local+partner recommended)
flexscale.normal_data_blocks on         (same value in local+partner recommended)
flexscale.pcs_high_res       off        (same value in local+partner recommended)
flexscale.pcs_size           0GB        (same value in local+partner recommended)
but
license shows
flex_scale not licensed
TDUBB1234
sysconfig shows I have it
slot 1: Performance Acceleration Module II 256 GB
                         State:     Enabled
thomas_glodde
1) have the physical card installed (sysconfig shows it, fine)
2) have the software license "flash_cache" installed (not sure)
3) have "options flexscale.enable on" (your output shows it enabled)
4) run "stats show -p flexscale-access -i 1" to see if the card is doing something
TDUBB1234
shows
Cache                                               Reads       Writes      Disk Reads
Usage    Hit   Meta   Miss Hit Evict Inval Insert Chain Blocks Chain Blocks  Replaced
     %     /s     /s     /s   %    /s    /s     /s    /s     /s    /s     /s        /s
    57      0      0      0   0     0     0      0     0      0     0      0         0
    57      7      7      2  72     0     2      0     7      7     0      0         7
    57      2      2      4  33     0     0      0     2      2     0      0         2
    57      9      9      2  81     0     0      0     9      9     0      0         9
    57     20     20      4  83     0     0      0    20     20     0      0        20
    57      2      2      1  66     0     0      0     2      2     0      0         2
    57    207    207     10  95     0     2      0   207    207     0      0       207
    57      0      0      4   0     0     0      0     0      0     0      0         0
    57     26     26      3  89     0    56      0    25     26     0      0        25
    57      1      1      0 100     0     0      0     1      1     0      0         1
    57      5      5      1  83     0     2      0     2      5     0      0         2
thomas_glodde
Your flash cache card is running fine. Its 57% full (Usage % row) and does replace a few disk reads already (Hit/s row).
