Data Backup and Recovery
copy to a USB/external drive
not_a_Lone_wolf
Hi Team,
I checked and found that 8.3> smtape could be used only to backup to a tape and not usb. Is it possible to copy the data to an usb/external disk drive using an alternate method from FAS systems? The system is used solely as NAS
One thought is mount the volume on host and leverage the host side capability. Any view/suggestions would be appreciated.
TIA
3 REPLIES 3
donny_lang
We've always just done exactly what you described (mount volume on host, copy to USB) and it has worked out quite well.
not_a_Lone_wolf
Thanks for sharing the insights @donny_lang  and @Sergey_Osipov.   🙂
Sergey_Osipov
Here is a KB of how to use smtape copy to external USB drive
https://kb.netapp.com/Advice_and_Troubleshooting/Data_Protection_and_Security/SnapMirror/How_to__consider_for_using_Smtape_to_seed_a_SnapMirror_relati...
Please bear in mind that this primarily can be used in testing purposes or to replicate baseline snapmirror transfer to a destination system in infrastructure with a pure connection between source and destination.
