NetApp Console
AVA-c4 AWS, SNMP issue
doenges
Hi there,
after enabling monitoring via SNMP, error in red indicates: "..... because SNMP subsystem is not running."
It appears that snmpd on AVA-c4 in AWS is stopped by default. What needs to be done to start it and enable it automatically upon reboot?
tia,
Oliver
1 REPLY 1
chriswong
Hi,
The SNMP service can be enabled manually via the command line. SSH to the AltaVault appliance, and issue the commands:
enable
configure terminal
snmp-server enable
You may refer to other SNMP commands in the AltaVault CLI guide, available as part of the AltaVault documentation available from the support website.
http://mysupport.netapp.com/documentation/productlibrary/index.html?productID=62032
Regards,
Christopher
