NetApp Console
BlueXP Advanced Mode
rbracker
What happened to the Advanced View in BlueXP? We have been using the Advanced View to set QTrees and Quotas for our volumes in AWS FSx for OnTap. I know we can setup and manage QTrees and Quotas via CLI, but BlueXP simplified the process and this functionality seems to have been removed recently.
1 ACCEPTED SOLUTION
rbracker
Found the solution. From the Canvas, select the desired Working Environment. On the right side of the window, select System Manager under Services. This will take you into what used to be called Advanced View.
3 REPLIES 3
mtorresBW
We are having the same issue. It was there just a few days ago.
rbracker
Adithya_Kameswaran
Hello @rbracker and @mtorresBW ,
As mentioned by @rbracker , you can single click on the working environment in the BlueXP Canvas, and choose the System Manager from the services that pop-up on the right hand side of the screen as below:
