NetApp Console
Classification volume discovery using wrong interface
AndrewPDX
Hi all,
I'm fairly new to this product but was able to get the connector and classification appliances installed and connected together, and with my on-prem clusters. However, I'm running into an issue on a few of my SVMs where the classification appliance appears to be "discovering" the volumes using the incorrect LIFs; that is, on LIFs that are either unrouted or on a different VLAN from the appliance.
I've confirmed that the SVMs in question do have LIFs on the correct/same VLAN as the appliance, and the export policies are all set to allow the connection. Checking access via the check-access command shows that connections are allowed using the LIF on the same VLAN.
Is there any way to force these volumes to use a particular LIF? Or a way to tell why they are preferring a "bad" LIF over the one on the same VLAN?
Thanks!
1 ACCEPTED SOLUTION
devvik
This happens when SVM having more than one IP while  discovering a volume in BlueXP Classification, One can fix it using the steps mentioned in below KB or just perform the below action item:
-- Create a default Ethernet interface on the Datasense VM and Connector VM to the same network/vlan as the SMB LIF on the ONTAP node.
https://kb.netapp.com/Cloud/BlueXP/Cloud_Data_Sense/Classification_discovers_wrong_SVM_IP
1 REPLY 1
devvik
