NetApp Console
Using FSx System Manager via BlueXP to configure SnapMirror between FSx and on-premis ONTAP
Jun11
We can operate Amazon FSx for NetApp ONTAP using System Manager via BlueXP, but can we manage things like SnapMirror relationship creation from this System Manager? Are there any features that are not available in FSx's System Manager compared to the on-premise System Manager?
The intent of this question is to see if it is possible to configure SnapMirror between FSx and on-premise ONTAP storage using only System Manager.
1 ACCEPTED SOLUTION
AmitKerkar
yes, you can (without needing ONTAP CLI or other tools)
yes, possible.
Pl remember that ,  when you use SM from BlueXP for an FSx , you are using an embedded version of ONTAP SM tailored to the FSx instance. Here you can't configure physical components or some system settings. There are limitations in case of encryption mismatch and a few advance configurations.
AFAIK features like hardware diagnostics and cluster wide settings are not there as physical layer is managed by AWS. Also, there is limitation when you have multiple HA-pairs
2 REPLIES 2
AmitKerkar
yes, possible.
Jun11
Thanks for the very useful information!
