Network and Storage Protocols
CIFS LIF IP not reachable on when hosted on port Type VLAN
SKT
CIFS LIF IP not reachable on when hosted on port Type VLAN ( a0a-200, a0a-150 etc..)
But works fine moved to port type if-grp (a0a)
any further configuration needed on NetApp end?
We are using Cisco switches for the data 10Gbps connectivity.
We have both singlemode and multimode_lacp policies for two different clusters for ifgrp ;
but same errors on both setup.
1 ACCEPTED SOLUTION
liu
2 REPLIES 2
liu
Set the Native VLAN on the switches back to the default (VLAN1)
ONTAP 9 LIF configured for a VLAN is unreachable when native VLAN is present - NetApp Knowledge Base
Check the operation configuration and startup configuration of the cisco switch
How to check differences between running and startup config of a Cisco cluster switch - NetApp Knowledge Base
SKT
After moving to trunk (mode active) from access mode on the Cisco switch side fixed the issue.
