Network and Storage Protocols
CIFS Shares Issue
Ken28562
I have a FAS2554 running 8.3P1 Cluster Mode and am runing into the following problem.
Whenever I try to modify permissions on sub folders in Windows Explorer, I get the following error:
The program cannot open the required dialog box because it cannot determine whether the computer named "IPADDRESS" is joined to a domain. Close this message and try again.
Then a second box pops up:
Unable to display the user selection dialog. The remote procedure call failed.
We are running Server 2012R2, have already ran through CIFS Setup and it is seeing our kerberos, ms_ldap, ms_dc and showing our FQDN.
Has anyone else seen this before?
3 REPLIES 3
Naveenpusuluru
Hi @Ken28562
Can you please send me the output of the below commands.
vserver cifs domain discovered-servers show
vserver cifs show -instance
Vserver cifs share show <share name>
Ken28562
vserver cifs domain discovered-servers show:
All Kerberos showing undetermined
2/4 MS-LDAP showing unreachable
2/4 MS-LDAP showing undetermined
2/4 MS-DC showing ok
1/4 MS-DC showing unreachable
1/4 MS-DC showing undetermined
Vserver: XX-XX-nas-01
CIFS Server NetBIOS Name: SAME AS Vserver
NetBIOS Domain/Workgroup Name: XXXXX
FQDN:XXXX.XXXX.XXXX.XXXX.XXX
Default Site Used: BLANK
Auth Style: domain
CIFS Server Admin Status: up
Description: BLANK
List of NetBIOS Alias: BLANK
BLANDATFAU
We're having this issue too, were you able to find a resolution?
