Network and Storage Protocols
Can't set FR = 0 if volume is thin
nsitps1976
I have created a none space guaranteed SAN volume with system manager, when I try to edit the volume and set the fractional reserve to 0% I receive an error  stating could not set FR = 0%????
1 ACCEPTED SOLUTION
fjohn
DOT 8.0 has the same limitations as DOT 7.3.1 in this regard.  DOT 8.0.1 does not have the restriction.
J
6 REPLIES 6
fjohn
What version of Data ONTAP?  In 7.3.2 and prior, you must set the FR=100 to set the volume reservation to none.  Data ONTAP 7.3.3 and later no longer have this restriction.
J
nsitps1976
DOT 8.0 - This is with the simulator howerver.
fjohn
J
nsitps1976
Thanks
radek_kubka
Hi,
The behaviour of thinly provisioned volume when FR "can't" be set to zero is a bit odd though - have a look at these two posts:
http://communities.netapp.com/message/30440#30440
http://communities.netapp.com/message/30522#30522
Regards,
Radek
nsitps1976
Thanks, I will take a look at these.
Regards
