Network and Storage Protocols
Confusing KB articles about IP Fastpath interaction with multi VIF (trunk)
aborzenkov
Accidentally hit two articles with completely opposite content.
https://kb.netapp.com/support/index?page=content&id=3011977: Does the filer support Etherchannel? states that ip.fastpath will answer on the same physical interface of a trunk that packet came in:
With fastpath, the interface, on which the request came in, and the MAC  address of the caller is saved on input. The reply is delivered on the  same link using the saved src MAC address, except that it is now the dst  MAC address. This avoids a route and an arp lookup. If the filer is  connected to a switch, the switch will distribute NFS (or CIFS or HTTP)  requests as they flow into the filer. Since the filer responds on the  same physical interface as the one on which the request was received,  there is no need to distribute responses out to the physical links on  the trunk. Basically, the filer load-balances over the links of the  trunk without having to de-multiplex the traffic out. Non-fastpath  traffic and broadcasts are always sent out on one of the links of the  trunk. One of the physical links in the trunk is marked as the "primary  link" of the trunk. Non-fastpath frames, broadcast frames, etc., are  sent on this "primary link."
https://kb.netapp.com/support/index?page=content&id=3011178: How does a multimode vif interact with ip.fastpath? clearly explains:
Therefore the fastpath-function will only see vif-interfaces as a single  interface.  ip.fastpath will not be aware of the individual physical  ports or 1st level vifs/ifgrps that are members of the top level  vif/ifgrp.
Which one is correct?
5 REPLIES 5
rkaramchedu1
The first KB link must be wrong - cause they yanked it...
aborzenkov
I am not sure what do you mean. The first article is there as well as part I quoted.
rkaramchedu1
I am getting a "Article not found" error when I go to that link. Sure you are not seeing a cached page?
"Article Not Found
The article was not found, or is no longer available."
aborzenkov
Access rights issue?
rkaramchedu1
Got it. The link had a trailing ":" in it that was causing the error. It is indeed there. Now I guess we can get back to the original question
