Network and Storage Protocols
Create permission with computer management 2008 R2
m_lecoq
Hello
I have a concern with FAS 2040. I configured CIFS, it works perfectly. But I can not manage my spinning computer using Windows 2008 R2 Management. This function only on 2003.
Is there some specific thing to do on 2008 R2?
For information the firewall is disabled
Cordially
2 REPLIES 2
reena
Can you tell if this FAS2040 participating in the Windows 2008R2 domain as well ? Are these the trusting domains ? What about the username that you are using to manage the filer using Computer Management, is that part of the filer's local administrators group ?
One other thing to keep in mind, in Windows 2008R2, you don't need to right click "My Computer" and click "manage", rather you need to go to the Admin Tools and select "Computer Management" from there to connect to the filer.
-Reena
m_lecoq
Hello
Thank you for your solution I was going through "manage" and not by Computer Management in Admin tools
Thanks
