Network and Storage Protocols
Enabled/Disabled virtual interface?
bmccullough
I have two FAS3140 running NetApp Release 7.3.1.1.  I am able to ping the IP addres of the first FAS but not the second FAS.  The second FAS is reporting they virtual interface as disabled!?!
I can ping out of the second FAS to other devices but not the reverse.
Help and thanks.
fas03> cf status
Cluster enabled, fas04 is up.
fas04> cf status
Cluster enabled, fas03 is up.
cat /mnt/fas03/etc/rc
hostname fas03
vif create lacp lvif1 -b ip e0a e0b e4a
vif create lacp lvif2 -b ip e4b e4c e4d
vif create single svif lvif1 lvif2
vlan create svif 340 348 351
ifconfig svif-340 `hostname`-svif-340 netmask 255.255.255.0 partner svif-340
ifconfig svif-348 `hostname`-svif-348 netmask 255.255.255.128 partner svif-348
ifconfig svif-351 `hostname`-svif-351 netmask 255.255.255.128 partner svif-351
ifconfig e0M `hostname`-e0M flowcontrol full netmask 255.255.255.0 partner e0M
route add default 10.13.240.1 1
route add net 10.13.244/24 10.13.244.1 1
routed on
options dns.enable off
options nis.enable off
savecore
fas03> ifconfig svif-340
svif-340: flags=948043<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.13.240.23 netmask 0xffffff00 broadcast 10.13.240.255
        partner svif-340 (not in use)
        ether 02:a0:98:0d:d1:a9 (Enabled virtual interface)
cat /mnt/fas04/etc/rc
hostname fas04
routed on
savecore
fas04> ifconfig svif-340
svif-340: flags=148043<UP,BROADCAST,RUNNING,MULTICAST,TCPCKSUM> mtu 1500
        inet 10.13.240.24 netmask 0xffffff00 broadcast 10.13.240.255
        ether 02:a0:98:0d:d1:d1 (Disabled virtual interface)
2 REPLIES 2
bmccullough
Ok the sub-vitrual interface is not correct, getting closer...
fas04> vif status lvif2
default: transmit 'IP Load balancing', VIF Type 'multi_mode', fail 'log'
lvif2: 0 links, transmit 'IP Load balancing', VIF Type 'lacp' fail 'default'
        VIF Status     Addr_set
(         VIF Status     Up      Addr_set             <-----      funtional entry would be )
        trunked: svif
        lag_inactive:
(        up:                                                    <----- funtional entry would be )
        e4b: state lag_inactive, since 17Nov2009 01:50:29 (6+19:21:34)
                mediatype: auto-1000t-fd-up
                flags: lacp enabled
                input packets 0, input bytes 0
                input lacp packets 0, output lacp packets 588654
                output packets 588653, output bytes 72992972
                up indications 1, broken indications 0
                drops (if) 0, drops (link) 0
                indication: lag_inactive at 17Nov2009 01:50:29
                        consecutive 0, transitions 1
        e4c: state lag_inactive, since 17Nov2009 01:50:29 (6+19:21:34)
                flags: lacp enabled
        e4d: state lag_inactive, since 17Nov2009 01:50:29 (6+19:21:34)
                flags: lacp enabled
bmccullough
Fixed.  The issue was with the network settings on the cisco switches they FAS was plugged into.
Was:
interface GigabitEthernet1/25
channel-protocol lacp
channel-group 4 mode active
interface GigabitEthernet1/26
interface GigabitEthernet1/27
should of been;
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 340,344,348,351
switchport mode trunk
