Network and Storage Protocols
Expand NFS volume
fajarpri2
Hi all,
I'm on DOT 8.1.
Usually I use iSCSI lun, but now I have an NFS volume exported.
What I'm not sure is, can I expand an NFS volume just like that?
vol vol1 +200G
Do I have to do something about the NFS?
Reason I ask is for iSCSI it's considered as block device, DOT doesn't have to concern about the filesystem.
But since NFS is filesystem, I think DOT should do something to expand the volume? Does DOT do it automagically or I have to do something?
Thank you.
1 ACCEPTED SOLUTION
aborzenkov
No, you do not need to do anything. Command is effective immediately. It is “vol size” BTW (“size” was missing in your example).
2 REPLIES 2
aborzenkov
fajarpri2
Thank you very much
