Network and Storage Protocols
FAS2020 - Controller not found
labadministrator
Hello,
I'm trying to install and launch the FAS Easy-Start Wizard.
I finished the following steps of  the Installation and Setup Guide (FAS Easy-Start Wizard 1.1 for iSCSI Protocol on Windows):
1- Controller discovery;
2- Controller configuration;
3- Storage provisioning.
But now, when i try use the FAS Easy-Start Wizard, i receive the message:  " Controller(s) not found  - There were no controller(s) found for the specified IP address. Please verify the IP address suplied and make sure the controller is visible on the network. "
What can i do ?
Thanks.
2 REPLIES 2
fcerezoafina
Hello
As far as I know the Fas start easy wizard had end of life. You can check it in the now page.
The new management tool is System manager for windows. You can download it from the now page.
Regards
labadministrator
Thanks for your answer !
