Network and Storage Protocols
Fibre Channel Direct Attach With NetApp Storage: Simpler SAN For The Right Environments
TSPresler
SAN complexity is often treated as a fixed cost of block storage. Fibre Channel Direct Attach, available with NetApp’s ONTAP 9.19.1, gives customers a simpler option when they do not need the scale and policy model of a full FC fabric. The result is a cleaner architecture, lower infrastructure cost, faster deployment, and more predictable host-to-array performance.
Just as important, FC Direct Attach can be treated as a valid SAN design point —not a compromise pattern. In edge, remote, cost-sensitive, and otherwise bounded environments, it delivers enterprise block outcomes without forcing a fabric-first design.
Design Boundaries
The most useful way to position FC Direct Attach is through environment fit. The model is best when host counts are known and bounded, ownership is clear, and expansion patterns are predictable.
Teams are generally better served by switch-attached fabric when they need higher fan-out, frequent topology changes, broad zoning policy flexibility, or long-range expansion options. In other words, this is not about good versus bad design —it is about matching SAN topology to workload scope.
Where FC Direct Attach Fits Best
Direct attach is especially useful in environments where simplicity and repeatability matter more than broad fan-out. Typical good-fit use cases include:
  • Edge or ROBO deployments with predictable host growth
  • Small clusters, typically in the two-to-four-host range
  • Test and development environments
  • Cost-constrained deployments that still require strong SAN behavior
Technical Value
At a technical level, FC Direct Attach enables per-port direct attach (DA) with one SCSI or NVMe LIF per DA port. This creates a flatter data path and reduces operational overhead tied to external switching layers.
Key technical benefits include:
  • Simpler setup and troubleshooting with fewer moving parts
  • Reduced TCO and administrative complexities from FC switch elimination
  • Lower latency potential from fewer topology hops
  • Dedicated bandwidth per host for stronger performance predictability
  • Clearer fault isolation tied directly to host links and array ports
High availability remains part of the design. With multipath FC across redundant host and controller ports, teams can build resilient direct-attach connectivity even without an external fabric switch. This does not mirror every capability of large dual-fabric SAN designs, but it provides a credible HA model for bounded deployments.
NetApp ASA – Block Optimized, Simple, Reliable
NetApp ASA is designed for simplified SAN deployment where FC Direct Attach sharpens the value proposition for customers who need superior performance without switched fabric overhead. The economics are structural: fewer components, less cabling complexity, and lower day-2 management drag.
This also aligns with the purpose-built ASA block capabilities around simplicity (deployment, configuration, management, provisioning, automatic load balancing), reliability/resiliency, security and enterprise data services. The combination supports a clear message: simplify topology where it makes sense, while preserving enterprise block credibility.
Real-World implementation
Consider a global consumer goods manufacturer assessing storage standardization across more than 500 bottling and manufacturing facilities. Many sites already operate Fibre Channel direct connect without FC fabrics as a deliberate cost and simplicity choice. With FC Direct Attach in ONTAP 9.19.1, NetApp AFF, ASA and FAS storage can support those locations without adding a switch layer or forcing topology exceptions, enabling one block platform and one operational model across diverse site types.
The Takeaway
With Fibre Channel Direct Attach, you can keep the architecture straightforward while still leveraging the core strengths of FC: deterministic behavior, well-understood operational models, and consistent performance. It’s a strong fit for environments budgeted for cost that want clean connectivity, faster bring-up, simplicity and fewer dependencies.
Getting Started
Start by identifying direct-attach-fit locations: bounded host counts, predictable growth, and limited on-site SAN specialization.  Keep a dual-track architecture standard: direct attach where simplicity and cost savings are the value drivers, switched fabric where scale and policy needs justify it.
For More Information
Fibre Channel Direct Attach is supported on the following NetApp block products – our dedicated block solution (ASA), our Unified All Flash (AFF) and our Hybrid Flash (FAS) with ONTAP 9.19.1.
https://docs.netapp.com/us-en/ontap/san-config/configure-fc-nvme-hosts-ha-pairs-reference.html
0 REPLIES 0
